Avatar
nicoara
nicoara
Username
nicoara
Joined
Visits
18
Last Active
Roles
Member
  • Thanks William. We knew about the forum link you mentioned before asking the question.  Yes, probably bipolar and sequential montage are the same thing. If your solution is to use Y-cables, then: Who can assist is through this process (could be…
  • Restarting the entire process again, somehow the error disappeared. For completion, I solved for ddf.minim.analysis by installing the library Minim from the Import Library. Thank you
  • Hello wjcroft,Thank you for helping me, the second link fixed the error.  Unfortunately, I have a new error now. The window for openbci opens quickly then crashes. I have looked online for help, it seems to be an opengl problem. Also, it may be …
  • Hello William, Thanks for the reference! Sorry for the late response.  After copying the instructions there  (I have folders C:\Users\nicoara\Documents\Processing\OpenBCI_GUI, C:\Users\nicoara\Documents\Processing\libraries\controlP5, C:\U…
