nabi
nabi
I recently encountered a problem with the connection of the board. I have two Cyton boards, and in our college lab, we need to use both boards in the same room. However, apparently, it is not possible to use both boards simultaneously because only one board is detected in the COM port at a time. If one Cyton board is already connected, the second board cannot be connected anymore.
Has anyone else experienced this issue? I would really appreciate any help.
Thank you,
Nabi
- nabi
- Wien
- 100
- Wien
Hello, I didn't quite understand—how can you determine which dongle should connect to which board? Because I don't see a channel setting in the GUI where this can be configured. Can you please explain that in more detail? i use at the moment Openbci…
yes i did, They suggested me to ask here if anyone has had the same issue.
thanks for your help, it works now.
hi wjcroft, I have already tried everything you said, but it still doesn't work. In the time series, I have a stable signal and everything looks normal, but in the Dino game, it keeps jumping. I really don't know what it could be due to.
Hi everyone, I'm working on controlling the Dino game using EMG signals, but I'm encountering an issue. The Dino keeps jumping continuously, no matter how I adjust the threshold or time_thres values. I've tried modifying both, but the problem per…
Thanks, have already tried that, but it didn't work. i gonna try to find a better position to improve the signals-quality. Best regards
i have another quastion about ECG signals. i am using Ganglion and Cython board. when i am using cython i get claen ECG-Signals but when i use Ganglion i get low-Amplitude-Signals. can some body help me out and tell me what can i do to strenghten th…
no,i don't, i already found the problem. the issue was that my board was near the power source and it produced some noice. now i can measure clean EMG signals.
thanks wjcroft, but i already knew it. i had the switchs in correct position.
hi DashBarkhuss, I am using Windows 11 and have set the band pass in the Ganglion software, but it didn't help much.
https://github.com/openbci-archive/Docs/blob/master/Tutorials/024-EMG-Setup.md i did the same thing as in this website but it did not work
