Default Avatar
muratkanc
muratkanc
Username
muratkanc
Location
Izmir/Turkiye
Joined
Visits
22
Last Active
Roles
Member
Location
Izmir/Turkiye
  • Everything is kinda ok. Device get affected if i'm "between" connection. Dongle must face directly my back. Also, close-range USB devices affects connection heavily. It could be better with just cables. I will buy USB extension cable
  • Ok, after replacing batteries problem is mostly solved. I see only 1 packet drop per sec awhile. Seems like Cyton drains amperes. Maybe adding some shunt resistor to show battery status via LED? PCB has plenty of space. Or OpenBCI_GUI interface can …
  • We got device around end-of-summer and didn't used well to this day. Hard to notice since it is EEG anyway. I will buy some extra batteries tomorrow and respond if problem persists. My thesis is about SSVEP-based BCI. Therefore, single drops per se…
  • Changing channels did not worked. I suspect RFD22301, either dongle or device, has broken antenna. It seems like they're obsolete and i can't find them easily. I reprogrammed Cyton for 3.1.2. We bought them after June 2019. I suspect antennas and b…
  • Thanks for responses. However, i tested this device both at home and university lab. Both desktop and laptop PCs. Is there any possibility that this RFD22301 is damaged?
