michaeljob
michaeljob
- michaeljob
- Basel, CH
- 16
- Basel, CH
with OpenBCI_NodeJS_Cyton is runs; the bug is in our IP6 variant, what I find curious that it works on one machine (win) and not on the other (mac) - I guess the various python conda env. have something to do with it; as for now hardware and node.js…
Hi William, thank you so much for the answer. 1) the Cyton works fine in all versions except in my IP6 project "npm run mind" on my mac! (this does run on win10) 2) yes, hardware is fine as it works in all other scenarios 3) as it is running in …
Hi William, when you start / initialize the board, there is a boolean: simulate, which can be set to true, so that sample data are generated by random, for testing. But actually the board also stops when simulate is false and I use the hardware. So …
now looking into averaging samples and we used larger angle of presentation... is there anybody with experience in openBCI and P300 ?
