mcneillk
mcneillk
- mcneillk
- 12
Thanks for your response. Adding my user to the "dialout" group worked after logging out and back in. I hadn't noticed the fix is mentioned in the main GUI page for Linux users under "serial port permissions". All is good.
Yes, that would absolutely be a valuable upgrade to the GUI since power values are so widely used. Also, I had the thought of proposing to re-implement the old "focus" widget in the GUI using a common EEG feedback approach, which centers around powe…
Ok, that makes sense. I was aiming to determine how accurate the band power values are as implemented in the old code because I currently use them (via UDP) to drive downstream calculations for experimental neurofeedback application. I would prefer …
The above link does not address my question about why the GUI code in DataProcessing.pde is different from other cited implementations, including explanation cited at Mathworks.
