Avatar
marshmallow
marshmallow
Username
marshmallow
Joined
Visits
50
Last Active
Roles
Member
  • I have got the same issue. I replaced the diode D9, plugged in a 3.5V battery and got no response. Now when i check, the diode is again blown. Kindly help me figure out the issue.
  • @Couby I am modifying the designs on DesignSpark. I have a slight confusion. I though i should ask you too since you have made the designs from scratch.  The resistor R5 (1M ohms, connected to pins 62, 63 of ADS1299) when translated to pcb g…
  • @biomurph I am modifying the designs on DesignSpark. The resistor R5 (1M ohms, connected to pins 62, 63 of ADS1299) when translated to pcb gives a relatively larger footprint of 0402 (with rectangular pads) as compared to the capacitor (e.g. C16 con…
