manneokoko
manneokoko
- manneokoko
- 19
Very nice if Ultracortex works with Q-wiz. But I read somewhere that dry sensors need to have very short wires to give good signal. If using Ultracortex with Q wiz, its not possible to place the amp on the headset, which means that long cables would…
William, will the OpenEEG emulation work right away for the forthcoming ganglion? Does it support 4 ch? Then I'd think that Ganglion already works in Bioexplorer..? Very intresting with the velcro and saline .. As a second choice after ultracortex.…
Yeah, Pete seems like a great guy and i really would like to start with the Brain Trainer system. What i was hoping for was to be able to use OpenBCI with braintrainer, to avoid the hassle of using wet electrodes. I was also askimg the OpenBCI devs…
Hi, The person Im refering to is Peter van Deusen of Brain trainer. He has been doing neurofeedback for a long time, and is sceptic to a dry electrodes for Neurofeedback. Since he has seen many "breakthroughs" in dry electrodes over the years, and o…
Hello, can somebody who own a OpenBCI confirm that the signal is as good as with wet electrodes? Ive had a conversation with one of the authorities of neurofeedback about OpenBCI, his opinion is that its impossible to make a headset with good dry el…
