mangoez
mangoez
- mangoez
- Australia
- 18
- Australia
Notch filter did the trick, you're an unsung hero on this forum mate! The help is very much appreciated.
Hmmm that makes sense but I tried it and these are the results, still bad. Even though I filtered it (one on the left) it doesn't look like EEG signals and the magnitudes are still too high. I have a low pass of 50Hz and highpass of 1Hz with a bu…
Well, I set the the port to be open for 10 seconds when using BrainFlow. I see, I guess what I should be asking is what is the best way to synchronise data and record an event? Im looking for an event that happens in a 200ms window so I do need …
Thanks William! After testing Brainflow for 10 seconds I am getting 2484 samples which means it's only off by 16 samples. This means I can use the python datetime objects to synchronise with the timestamps I get from data right?
Thanks man, so from what I understand the timestamps on the EEG data are what are received at the end, hence not are not exactly when the EEG samples were actually recorded. This results in some latency issues and some samples are omitted. If I s…
