lopezst1
lopezst1
- lopezst1
- United States
- 23
- United States
They are honoring an exchange for a new ganglion. Very happy I was able to get this resolved, thanks again for the help.
Oh that'd be great. I've reached out to them and they said they are reviewing, thanks for your help!
Here is a picture from a session I had recently, this one is especially bad. Channel one had an electrode firmly attached to my head, the rest of the channels had no electrodes attached. Usually when no electrode is attached the line will be flat, f…
The impedance widget does not work for me, but I will post screenshots of the gui as soon as I can.
The plating looks ok and my friend who has a working cyton used all his equipment on my ganglion and was also seeing the 20hz noise. It does appear to be an issue with the hardware itself as far as I can tell.
I will fire up the ganglion tonight and report back here with some actual figures. Thanks for your help! I will say that I have the alligator ear clips from FRI with the silver discs. I usually keep my electrodes in place using a headband. The conne…
Sorry it has been awhile since I posted this. I am able to get a relatively clean signal with a gel but rarely without it. Whenever I try dry electrodes there is a consistent 20 hz noise. My friend has a new cyton and is able to get his signal witho…
I am also noticing this in my data. These bursts come at infrequent intervals and have occurred in different rooms throughout the house. Any ideas as to why?
Let me clarify, I am getting >200 uv without an electrode even on the lead wire, same when I do have an electrode on there. I will have it laying on my bed and the signal will be going nuts. I have tried to capture EMG on my arm, face, etc. but t…
My signal varies quite a bit, from 200 mv all the way up to 1000+. I am using dry electrodes most of the time.
My mains is 60hz. This ganglion has sporadically worked for me but generally the signal has been noisy. There will be brief moments where the signal clears up before becoming noisy again. When I use conductive gel it seems to work more often. I have…
To anyone else who sees this, if you dowload the latest version of the GUI (August 18) from Github and run the GUI through Processing, the app does not freeze when running LSL.
Yes I saw that one. I will log my issue there for tracking. Will try running from processing and see how it goes. Thanks.
