Default Avatar
lookfwd
lookfwd
Username
lookfwd
Location
New York
Joined
Visits
61
Last Active
Roles
Member
Location
New York
  • Hello @tangte, Thank you for clarifying the single 5V case. Makes perfect sense. After writing the post above, I spent about a week setting up the ADS1299 Performance Demonstration Kit to generate Bode plots. The image shows a transformer but …
  • It would be wonderful if there was at some point a clear answer to the BIASINV story. I've gone through all the threads that mention it and there are very aggressive answers pointing to inconclusive to say the least references. The TI forum link …
  • Using magnetoencephalography (MEG), a non-invasive neuroimaging technique in which thousands of brain activity measurements are taken per second, we showcase an AI system capable of decoding the unfolding of visual representations in the brain with …
  • The holy grail of BCI - will have to read it. Ok - I had a look - words might produce similar brain wave patterns effectively convey the intended sentiment I'm wondering if they catch the sentiment or subtle motor-related signals fr…
  • I kind of like Dr. Cody. He's somewhat "pop"... popping in my social media for sure. I can see the excitement with ChatGPT. I think as he gets to Tensorflow and Eden AI and azure etc. likely he will feel that this derails him from his core niche, be…
  • I've seen some @vinnyMS1 's code here: https://openbci.com/forum/index.php?p=/discussion/comment/19444/#Comment_19444
