little_snow
little_snow
- little_snow
- little_snow
- 30
- little_snow
I have a few questions regarding your response to me, and I look forward to your answer: 1. I am currently using the built-in virtual data, and even after data verification, the prediction still does not display blue 2. Is it necessary to use real…
I am glad to receive your reply. The question you asked is shown in the picture. Also, I am using the window11 system, and I am not sure if this has any impact. Thank you again for your reply. @dream4future said: What Java version do you …
After installing MindAffect and using the commands in the tutorial for testing, the tutorial states that if you press 2 now, you should see a flashing "buttons" grid, as shown below. You should see a random Panic briefly flashing green (it is the ta…
I would like to consult with you about a new question. Currently, I have two types of electrodes available for collecting electroencephalogram (EEG) data, as shown in Figure 1 and Figure 2. If you want to collect SSVEP data, which electrode is more …
Thank you very much for answering my question. It has been a great help to me. There is another question that I need to confirm with you. If I use the openbci GUI to obtain data and select 8 channels in the settings, will this problem not occur. Tha…
I really want to know how you found out from the screenshot that I am using 16 channels? I obtained the data using BrainFlow in Python, and there is a line of code that sets up the Cyton board. Isn't the setting of the code 'board_id=BoardIds. CYTON…
Hello, the device I purchased is the Cyton+Daisy, but I only used the Cyton board and cropped the raw data obtained, retaining only eight channels of data. This is the data shown in my picture now. I would like to know what caused this situation so …
This is the dry electrode I am using.
The device I am using is a Cyton board, I use 8 channels which adopts dry electrode acquisition. How to reduce lead resistance, and the electrode connection I am using is shown in the figure. Does it have an impact on the collected data? thank you.…
I have also encountered the same problem. The frequency of SSVEP data collected is completely incorrect, and the collected data seems to have some issues, as shown in the figure. Each interval data is the same. What is the reason for this abnormalit…
