lisapelagalli
lisapelagalli
- lisapelagalli
- Italy
- 19
- Italy
Hi William, thank you for your advises. I will send some photos and descriptions about this system as soon as the set up is completed. Regards, Lisa
Hi William, I noticed that BCI2000 works only if SampleBlockSize/Sampling rate is equal or a submultiple of Stimulus Duration. So I changed SampleBlockSize to 15 and sampling rate to 125 Hz, so I have 120 ms of Stimulus Duration. Now the P3 Spelle…
Hi William! Thank you very much for the precious clarifications, I will follow your advices. I don't know others who had success with BCI2000 spellers. I've only read some studies about OpenVibe, but I will keep you informed about the results of my…
I'm connecting BCI2000 to Cyton with a direct serial port driver. I said "because it sends data to buffer every half second" because I read it in this page: https://www.bci2000.org/mediawiki/index.php/Contributions:OpenBCISource When I try to modif…
