Default Avatar
laeeq24
laeeq24
Username
laeeq24
Location
pakistan
Joined
Visits
36
Last Active
Roles
Member
Location
pakistan
  • Hey;I made a pcb for ads1299 with pic32, using minimum distance 5 mil and minimum trace width is 10 mil. I have gound planes and I separated ground planes for digital ground and analog ground. Now I want to develop my PCB so should I develop as Impe…
  • Yes, we are using 10 class Kingston 8 GB card which is working fine alone, i checked it by sending a, L , S, A and it start creating the file according to HEX name in EEPROM. I checked the schematic of EVM board but there is nothing to connected.
  • Hey William;As now we are working on chipkit-dp32 with ads1299 and using the defaultboard from openbci library. All the things working fine. I know the openbci and chipkit-dp32 pin_def.h have some changes. Any ways we have achieved the openbci worki…
  • Yes im following this tutorial, Thank you William for your kind and quick response. Now I will try to share my details and will take your help if i need somewhere.Thank you Regards
  • Dear William;I have attached the pictures of the ECG wave recently we got on GUI... Kindly tell me if you think we are doing something wrong or that wave is not good enough. Pic 1 https://drive.google.com/open?id=19Syv5sOKGzba212kXNyPhV6yw9EdfM…
  • Dear William;Last night I'm succeeded to visualize my hand noise signal on the GUI when I grab the bias electrode, the noisy signal goes to zero. I will tell you when if I'm able to visualize my ECG and EEG signal. 1- My code is working fine, th…
  • Yes, we are sending data in a given format: 1- 0xA0 2- 1 byte sample number 3- 24 byte ADS channel data 4- 6 bytes for accelerometer-----(we don't have an accelerometer so we send 0x00 multiply by 6) 5- 0xC0 I found that restarting problem i…
  • No I'm not achieved any success to view any valid waveform on GUI. The two things I did in code. 1- In serial Receive, I comment out the burger protocol code, Now any character it receives it just put it in testChar directly. so +b+ changes in to b …
  • Dear William;It sounds good and we are grateful for your help. As I told you that I'm using the code from this link https://github.com/OpenBCI/OpenBCI_8bit?files=1 All the things working fine I got an ID and register setting from ads1299. For visual…
  • Der wjcroft; Thanks for your reply and help, I will try to use this GUI you gave. I have few more questions. 1- When I send +b+ it starts streaming and serial monitor shows garbage...maybe due to serial.write command, any possibility to view the st…
