Avatar
knightv8
knightv8
Username
knightv8
Joined
Visits
105
Last Active
Roles
Member
  • Hey William,thanks for including them Yes I tried light, medium and hard tightening on the scalp. In fact when I tight them (when they start hurting quite a bit), the signal goes railed. I loose the tightening a bit and sometimes the inconsiste…
  • Hi William, I attached the electro-cap today and this is what I get, as expected, a clear signal.on all channels. Contact email haven't replied to me yet. If you have any more ideas in the meantime, please do let me know. I will update if they …
  • Thanks re:ohms. Understood will triple check on Friday. The electrodes come pre-assembled, you just screw them on the headset. I will tighten all the electrodes screws just in case. The O1 and O2 are inconsistent (check 1st screenshot). Sometime…
  • Ear clip same as the other electrodes, stable at 01.7 (with 200 Ohm setting). Just for my future reference are these values within acceptable range ? Yes I did. However it would be very unlucky to have eight electrodes that need wiggling/screw tig…
  • Hi William, I have tested 3 of the electrodes and showing a stable 01.7 on each one with (200 Ohm setting). .With a 2K Ohm setting it shows a stable .001. Is that within acceptable limits? Electronics aren't my stronghold. If these are wit…
  • Hey William,nice to speak to you again. Thanks for your prompt replies as always. I have just tried swapping SRB2 with the BIAS, same thing. I have tried changing the wires, but same result. Let me show you with some screenshots: Screensho…
  • that was my thought exactly... how was he able to get a 80uV on all A1 referenced channels... Did not know re:ADS1299 used in clinical equipment. Thanks. They must have some internal circuitry different then ours to be able to capture that sig…
  • I understand. I will make an assumption in my paper that clinical equipment might be more targeted to capture this artefact; at least from my findings. I stand to be corrected... The artefact was showing only on T3 and T4 since that was on bipolar…
  • Hi William,thanks once again for your prompt replies. Yes I though so as well re:article, but I have read so many books lately, I get mixed up who said what I think that those where using clinical EEG equipment, which would differ from our …
  • Hi William,many thanks for your reply. Yes you are right re:question title; I should have explained it better. Let me give you a few links: http://s32.postimg.org/jnahphp45/image.jpg (screenshot from book) https://www.scribd.com/doc…
