kirandivakar
kirandivakar
- kirandivakar
- USA
- 198
- USA
Ok. Final update. I installed older version. 3.0.1 stand-alone application on 64bit Windows 10 system on Lenovo Ideapad360. Used CSR dongle ordered from open BCI. Installed it with the CD that came with it. Used Zadig. Restarted the system with dong…
Ok. I tried 3.0.1. That worked, in the sense that Ganglion device appears in search. But is unable to connect. It says comport error??
@pushtheworld Which older version I should try? Kiran
I keep getting this error- "Code 412 Error: TypeError : Cannot read property 'state' of undefined" Is anyone else having same problem? KD
@pushthworld. I will be happy to try anything. I also got a BLED112 dongle. But still not resolved the issue. I am using windows 10, 64bit system. Thanks, Kiran
Hi guys, I have tried almost every solution mentioned above for past 48 hours. It has been frustrating an exasperating. Nothing has worked. I have new Lenovo ideapad 320 with Windows 10 system. I have got CSR dongle from openBCI. It came w…
