juldau
juldau
- juldau
- France
- 219
- France
@biomurph,I had D9 replaced and it worked, my OpenBCI is back to life! Thanks for the tip.
OK thanks for the ref, I'll look into it. Looks like you need some skills to solder that by hand but I'll try and let you know.
@biomorph,OK I used the "diode test" setting of my multimeter and measure D9 voltage (both directions as I don't know which is ground): I found 0. To make sure my measuring is correct, I tested D1 on the other side of the board and found 0.559V. So…
@biomorph Thanks for your answer. Power Supply: I use as power supply the 500mAh Adafruit battery pack coupled with the Adafruit PowerBoost (I have the 8 bit board expecting 5V as input) as suggested by wjcroft at the bottom of this page (https:/…
Hi all,follow up of my previous post: my 8 bit board looks dead, the LED stays off when I turn the swith on, no sign of any activity. Impossible to communicate with the board and upload the new firmware via Arduino IDE. Any suggestion ? Best.
Hi OpenBCI community,first of all, congrats for the great work and amazing device! I had the same problem a few months back with my 8 bit board: impossible to connect although it had worked really fine previously for a long period of time. I re-upl…
Hi, about wjcroft last comment on this thread: "OpenBCI (8 bit version), like most 5V Arduino boards, has regulators for both 5v and 3.3v." Does that mean I can use for my 8 bit version the same 3.7V battery pack as the one recommended for the 32 bi…
