juderb
juderb
- juderb
- 22
Thanks again @biomurph. I'm starting to look like a real doofus missing these details! My bad!
Thanks @biomurph. I see the correct RFduino header and c/cpp files now. Not sure how I overlooked them. Just a side note, it would be very helpful if you guys put together an API/SDK programming guide. This could encompass the custom RFduino libr…
Thanks for the quick response! That explains that. I also missed the comment to the same effect here: https://github.com/OpenBCI/Docs/blob/master/tutorials/03-Upload_Code_to_OpenBCI_Dongle.md Is the source-code for the custom library available? I …
Actually, that post was very helpful. Using the technique described, I confirmed the self-noise for all 8 channels is about 0.13 - 0.18 uV RMS. Thanks for the suggestion. I will hook the system up to a function generator and see what I can learn f…
No luck yet. It shows up when the leads are attached, but not connected to the body, so I am sure it is not from any kind of muscle activation. I have also isolated it as much as possible. I am trying to record the data to display here, but I am h…
Never mind, I found it in the repository OpenBCI/OpenBCI_Radios. The README in the OpenBCI_8Bit repository should have specified this.
It looks like the Daisy board may be damaged, likely from the extra soldering. It appears to have caused the solder to overflow between ADS1299 pins. In Image1, I see overflow pins 21 and 22 on the ADS1299. The same pins are bridged on my 8-bit BC…
That reference addresses the same exception type (NullPointerException), but at a completely different portion of the code. I downloaded and implemented this "Processing Debugger" to try to identify the source of the issue: http://debug.martinleop…
That did the trick! I have a Dell Inspiron 14z with Intel HD Graphics 3000. Just needed to head to intel and get the latest driver, ran no problem. I do get an extensive list of java exceptions when I start it though. I will investigate this f…
