jrseojr
jrseojr
- jrseojr
- Seoul, Korea
- 33
- Seoul, Korea
@wjcroft and @retiutut Thanks for your giving advice, I think that I solve my issue. Using an extension USB cable, I moved the USB dongle to be almost closed to Cyton (actually, I attached the USB dongle to the EEG headset with insulating tape). …
Hi! @wjcroft Thanks for answering, I will try based on your advice. I have another question. As you see in the screenshot, with some cycles (interval), similar shapes of patterns occurred. Originally, I thought that these came from an e…
@wjcroft and @Andrey1994 Thanks for answering. Ah... I have an additional question for the Cyton board and OpenBCI-GUI. As I mentioned above, I should use ThinkPulse™ Active Electrodes. Therefore, following the instruction of ThinkPluse, I set a…
@retiutut Thank you for giving the answer!! Well... Because of my previous EEG sensor, I may be too much familiar with OSC things. My issue may be solved soon! Cheers J
