joe_westra
joe_westra
- joe_westra
- CA
- 3
- CA
Thanks William, I have done as requested. That info on packet drop reporting is great to know, thanks! If Sean doesn't have any other suggestions right now I'll try updating the Cyton firmware and see if I have any more luck.\ Thanks again!
Thanks for the help William and Sean, I really appreciate it! William: -I was initially using 1000hz and 16 channels with 10ms latency over both TCP and UDP. As per your suggestion, changing to 5000hz while using TCP reduced the packet drop is…
For Linux users not running the GUI as sudo, they may need to add their user to the 'dialout' group to allow read/write access to the COM port.
