jgottlieb
jgottlieb
- jgottlieb
- 3
Thanks! I'd seen the example, though it seems specifically geared towards the subject pressing a button. I hadn't found those forum threads.
I was only doing it to test and make sure I could properly do a firmware flash. Out of curiosity, why do you think it is an important line of code? The only utility, so far as I can tell, is to allow the receiving computer to determine if any pack…
Okay. I can at least get it to talk to the board now, but after flashing the firmware straight out of the repo about 20 times now, I still get the verification error. To head off some of the common suggestions I keep reading - I have put new batte…
I have a 32 bit board. I have previous successfully streamed ECG and EEG data to the OpenBCI GUI. I am using a Mac. I was going through the instructions to make sure that I could flash new firmware. I successfully flashed the firmware from GitHu…
