jcyhuang
jcyhuang
- jcyhuang
- Philadelphia
- 34
- Philadelphia
Thank you as always @wjcroft. I think we decided to just stop/start the data streaming in place of the trigger, since we are only marking the beginning and end of the stimuli (i.e., the video).
Hi William, Thanks again for all your help! The 'x3' modes are turned on, when a JSON key 'redundancy' is detected. As you can see in the code this is available for both the tcp and udp modes. Maybe I'm just dense here. Could you point…
Hi William, Thank you for your response! Can you clarify? You mention "packet loss", is that with the default Bluetooth radio transfer, or are you referring to the Wifi Shield? Referring to the wifishield here. We've also observed hig…
Gotcha. Thanks William!
Thank you William @wjcroft! This might be a dumb question to ask but can we still use the Cyton board SDK even if we bind it with Daisy?
Thanks William! @wjcroft. The first 2 points make sense. For the last point, does that mean that our 3-lead ECG should really be 2-lead in this case when we are mixing EEG and ECG?
Hi @wjcroft ! Thanks so much for your response. A couple of questions - * We did read the page to set up our GUI. However, when we previously collected the data, we didn't know that we would need to reconfigure the board (i.e., turn off BIAS2 f…
