jaymutzafi
jaymutzafi
- jaymutzafi
- 3
F3 & F4, TP9 & TP10
My setup provides 30 seconds of 40hz at around 500 micro amps, not even perceptual. I'm running I think at around 5v peak to peak. It will go higher if resistance changes but I don't think it can go so high as to do damage. Now I know that I won't…
Thanks. This is extremely helpful! I am not using the OBCI GUI, I could not get it to work, I get a bunch of error messages, I fix one, 3 more show up. But Neuromore seems to pick it up instantly with zero set up. I am hoping that will suffice, un…
Also, if I specifically want to measure gamma, anything I should consider? (location, settings, etc')?
Thanks William, you are just super helpful on all forums I hate to admit this but I am just not technical enough or not versed in this enough to figure it out. The autodidacts tutorial is much more useful but the OBCI one is nearly incomprehensib…
