Avatar
james_dowsett
james_dowsett
Username
james_dowsett
Location
Oldenburg
Joined
Visits
35
Last Active
Roles
Member
Location
Oldenburg
  • Finally got everything working :-) You were right wjcroft, the channel number was incorrect, so I only needed to reflash the dongle. Thanks for the help.
  • I've managed to reflash the dongle, now I have a solid blue LED when I plug the dongle in, so it seems that worked. However when I try to upload code to the board I still get "No target found".So I guess the next step is to find a 0.1uF capacitor an…
  • I'm unable to re-upload the firmware. I have followed all the instructions in this thread:  http://openbci.com/forum/index.php?p=/discussion/comment/3624 and I am able to get it to compile in Arduino 1.6.5, but it will not upload, the error is "…
  • Hi Thanks for the reply, I read through the thread, the discussion was about an 8 bit board, whereas mine is a 32 bit, and I wasn’t sure if the LED should respond in the same way. What I wanted to confirm was; should the LED on the dongle remain on…
