jamaker
jamaker
- jamaker
- 109
I was able to get a signal with the 16 channels setting, but it was very choppy. Maybe this is because of the FTDI driver? The firmware is 3.1.2 thanks!
How can I set BDF export in the OpenBCI GUI? I couldn't find any export options. thanks! edit: Found it. I was looking with synthetic data selected...
Hi all, I was wondering if with the new WIFI-shield it would be possible to stack one or two more daisy board on top of the available 16 channels? Also, it's not 100% clear to me how you would stack these daisy modules. Has anybody tried to t…
Hi William, Thanks. The script with lsl is now working. But the other issue with loading plugins via user.py persists (after reinstalling everything). It's not a specific problem for the lsl plugin, but for all of them. User.py can't load any …
Ok, thanks. There are no other ready-made active electrodes available that are somehow compatible with OpenBCI?
William, I was wondering if you found out more about those nvk active electrodes? Will they work with the openBCI?
