jalevitt
jalevitt
- jalevitt
- Boston
- 20
- Boston
This is the exact code I've been using to test this, I removed it from the larger app so It could run on its own (it still has a variable called app, but its just a name). It should run on anyone's matlab environment, as long as you have LSL on your…
@retiutut I gave it a shot with the synthetic data mode, and got the same odd result with respect to the timestamps. Below is an image of my setup: I tried to upload a log file, but the forum wouldn't let me, so here's a link : https://github…
@wjcroft I just gave it a shot with OpenViBE, and everything seemed to be working properly, which is nice, but also confusing. @retiutut I've played around with my code more, and I'm not 100% sure, but it seems like the spacing between chunks is …
@retiutut I took a look at it. My limited understanding is that this problem could perhaps cause the discontinuity in the timestamps that I observed, but not the corresponding discontinuity in the actual data. So I'm still a bit lost.
@retiutut I am actually already using GUI version 5.0.0-beta.0, so I'm not sure that's the exact issue
