j_loe
j_loe
- j_loe
- 28
Ah true, guess I could have been clearer initially. OK, thanks. The board's arrived now so I'll check out the code. Totally agree about the second monitor. I've struggled in the past with generating accurate SSVEP stimuli! Thanks again
@retiutut said: Both. Great. And what signal processing is applied to identify SSVEP?
Hi Nekro and William, Just to piggyback on this thread I found that Arduino clocking speeds were actually slightly out of what's expected (in all 5 Arduino boards I tested!), with regards to using them to flicker LEDs (I'm assuming this is what you…
Hi, Yes, you can use a single LED to elicit SSVEP response, it just needs to be bright enough (although it doesn't have to be crazy bright) and the flashing frequency accurate. Someone has written about it here: Mouli, S., et al. (2015). A configu…
