isozyesil
isozyesil
- isozyesil
- 114
@wjcroft Thank you so much!!! I was struggling with this issue such a long period and it was my fault that getting SRB1 and SRB2 different. Thanks a lot again! Only Channel 15-16 coming railed now. What should I check again? )
My reference point as close was solder locations. This is why I was thinking as closest. Sorry for that. I will change and try, and let you know soon. Thank you @wjcroft.
Hello again @wjcroft you can find my SRB2 and BIAS connection pictures in the below. White one is Y cable. Black One on the Cython Board is my BIAS. http://i64.tinypic.com/2s8623o.jpg Front View http://tinypic.com/view.php?pic=4f4fr&…
@wjcroft As OpenBCI GUI the application that is provided by OpenBCI. When I use it, on the hardware options there is a button for SRB On/Off buttons. Headset works fine while SRB1 is ON ( All 16 channels). BIAS (Black cable) is connected to Cy…
Hi @wcroft, I think I did. When I run the test.py without putting the headset to my head, it is working normal but when I put it on Result is 8388607
First question solution Warning: ID:<158> instead of <192> In the library of BCI, daisy module should be set TRUE.
When I execute the test.log.py in python SDK, no record is saved to test.log; Except ---------LOG START------------- serial closed Is it normal? Thanks, Sefa
@wjcroft, thank you for your answer. As far as I understand, I need to 2 Y cables. don't you? I had one from the box, seems like I need to make other.
@wjcroft, Thanks for your answer. In the forum, you replied almost all questions . Cyton + Daisy board I have. I checked the link before but, when connect to device and try to see streaming data, there is encoding problem. How can I solve this …
