indra
indra
- indra
- 101
Update: My dongle works fine now. It does seem like a driver issue. I installed the FTDI driver (2.12.18) from http://www.ftdichip.com/Drivers/VCP.htm on a different system running Windows 7, after which it is now recognized on both Windows 7 …
Thank you William. I'll send an email.
I did a continuity test between AVSS and AGND. There is no continuity between AVSS and AGND.
@biomurph I think the problem might be with U3. The pins seem fine, but the chip gets heated up when the board is powered on.
Hi, I checked the voltages again. I'm not getting -2.5V between AGND and AVSS . I'm getting 0.5V between AGND and AVSS, +2.5 between AGND and AVDD 3.3V between AGND and DVDD
Hi, I have an 8-bit board which stopped working recently.I don't get any data streaming in, but an empty .txt file gets created. I tried measuring the voltages between the pins as mentioned above. I'm getting 3.3V between GND-DVDD and 2.5V betwee…
