Default Avatar
ilgarba
ilgarba
Username
ilgarba
Location
Italy
Joined
Visits
23
Last Active
Roles
Member
Location
Italy
  • Hi William, I had the wrong connection! I had indicated the wrong COM port! Now it sees correctly all the channels of the Cyton, but I still have a problem: the noise level is very high, practically always at 100, when it should be less than 5. I…
  • Thanks William! About the other question that I repost here, can you help me? I did some more testing and was only able to get debug mode to work (debug.json). Specifically: Double click on "online_bci.py" and opening the "debug.json" file. …
  • I'll also take the opportunity to ask you another question already. For my mother (sick with ALS) I would need to make a very simple screen with only two keys YES and NO and not the whole QWERTY keyboard, how can I do? Thank you very much! Hi, …
  • Hi William, thank you so much for your response! I did some more testing and was only able to get debug mode to work. Specifically: Double click on "online_bci.py" and opening the "debug.json" file. What is the correct file that should ultimate…
  • Thank you so much for your response! Do you think a 4 channel board is sufficient? Sorry for the ignorance, but in concrete terms having more channels available what does it allow you to do more? Detect different waves or always the same waves but…
  • Thank you so much William! You don't know what a pleasure it is to have read this response from you. I saw the video you posted and it is really very very interesting for my mom's needs. I'm sorry to take advantage of your kindness, but I woul…
  • Hi William! First of all thank you so much for your reply! When I talk about not being able to communicate, I mean that at the moment my mom is perfectly able to understand what we are saying to her, she just has difficulty in responding becau…
