henriqueandrade
henriqueandrade
- henriqueandrade
- Brazil
- 1
- Brazil
Hey @wjcroft ! Thanks for replying. It does not halt. As you said, stream produces all zero, but the signal display is running. What do I need to do to use the 'freeze detection' feature? Isn't it default when running the OpenVIBE acquisit…
The OpenBCI signal, for no clear reason, peaks and then goes to zero. I'm using OpenVIBE to visualize it.The only way to get it back to work is by resetting the dongle. Did anyone experience this issue before?
