Avatar
gvzb19
gvzb19
Username
gvzb19
Joined
Visits
29
Last Active
Roles
Member
  • @pushtheworld - Excellent - just ordered one! Getting past the bandwidth limitation of the bluetooth downlink and with the new functionality to integrate experiment presentation software and markers, OpenBCI is moving in the realm of a proper rese…
  • AJ,  Sorry for the trouble - I don't do Twitter.  Any chance I can preorder a shield?  Paypal? One quick question: does the current GUI work with the V3.0 firmware?  (I have made some changes to the V3.0 firmware that accepts makers and inser…
  • One more question, since the wifi is so much faster than the serial bluetooth would it be appropriate to add a "marker" channel to the data now - just a simple int.  If we do it now then all the raw data files will have the correct format.  If we do…
  • @pushtheworld, Thanks for your response.  I can see from all the posts and excitement for wifi that you are committing a lot of time here. I am not dev with superpowers.  However, I am an experienced hobbyist with knowledge of C/C++, Java and …
  • This is super exciting.   Two quick questions: * Does the OpenBCI_GUI software support a wifi connection yet?  Will it? * Is there a possibility to open a UDP port on the Wifi shield to listen for Markers/Stimulations to add to the data streams? Th…
  • Hi everyone, I recently purchased the OpenVIBE 15 board and I would like to use it for a Science Fair experiment.  For the experiment I need to get "stimulations"/"markers" into the data.  I have read all the posts I can find and the Tutorial on the…
