growernotshowerbrain
- growernotshowerbrain
- ga
- 32
- ga
I tried "Ganglion-xxxx" and "xx-xx-xx-xx-xx-xx"
I found the mac address in the GUI, and I tried putting the exact value in the brainflow ganglion element, and I don't know why but it still refused to work. Maybe because I manually installed brainflow via a python command before?
Yeah, i ran it and nrf mobile app as well. I'm not sure what the mac address was, as there was no specified value for it, but I assume (from a google search) 'BT address' is the same thing and used that, which didn't work unfortunately.
Thank you for all your effort William. I got into contact with customer support and they said it was okay to downgrade my board, so I did and it fixed the issue. I understand this can be a general issue that can be fixed with a patch on the develope…
Unfortunately, it did not work.
Yes, I tried both native and bled112 but to no avail for either. I am about to upgrade my firmware again and will report back.
I apologize for not reading through the thread first and causing more confusion.
I read through user jarek's thread and I currently have version 3.0.1, and it seems 3.0.2 has this issue fixed. I shall try to upgrade to 3.0.2 and see if it works.
Yeah, even the latest version of brainbay does not seem to work.
How do I recompile with the latest brainflow library?
Oh yes, I tried that, but it didn't work. My COM port is correct because I checked in device manager.
Where can I find the MAC address? Is it the same as BT address? I've looked in the nrf mobile app and Bluetooth LE Explorer but there's nothing that looks like a MAC address. Also, I have the latest brainbay already.
@wjcroft I'm not using brainflow currently. It's too complicated for me because I have to code. Also on the thread that user jarek created, you told me not to downgrade, may I ask why?
I may have messed up big time. My ganglion turned off mid-update. That may be the reason why it can't connect to either brainbay or openbci gui. However, it can connect to the nrf app so that's a bit weird. Is there any way to fix this? Edit: it …
I got it to work. I read the brainbay manual and saw that only one eeg source could be open at a time, so I just had to delete the previous EEG element and enter the ganglion element next.
@wjcroft do you think a ganglion with bioera is enough for a beginner who wants to fix/enhance their brain via neurofeedback? I also am thinking about learning more about clinical neurofeedback as I get better at this stuff, so I kind of want a 4 ch…
