grahambriggs
grahambriggs
- grahambriggs
- Corvallis
- 146
- Corvallis
- Website
- littlebytesofpi.com
Thank you for the reply. Sorry for the delay, as it appears that this branch is gone, maybe merged into development build for upcoming release? Is there a place to download an installer for latest build? I would be happy to do some testing if I can…
To follow up for anyone else who has interested, through experimentation I have confirmed the answer. When you use CytonSDK channel command and set bias to for a channel, it shows up in both the SENSP and SENSN register. Here is register report …
William Thank yo for prompt reply. This is all very helpful. I have looked at the data sheet. I see where the register bits map to the settings value for all items except one. OpenBCI Cyton SDK documentation talks about a single 'bias' setting. I…
Thanks, This makes sense. I will look into the d command.
The serial port address on the Raspberry pi will be different than on the mac. To determine the serial port address on the Pi, remove the dongle, then in a console window type in "ls /dev". Now plug in the dongle and type in "ls /dev" again. You …
William Thank you for taking the time to add these additional comments. Things make much more sense now. I am working with this equipment in my home office, which is chock full of laptops, mobile devices, lava lamps, routers, wifi hubs, and more…
William Thank you for the prompt reply. Regarding noise, this was just a quick test to get the screen capture showing the odd behavior of the raw data, and there is a lot of static electricity in my office chair ? I did use OpenBCI GUI softwa…
Khaled Today the software has several parts that are hard coded for the Cyton 8 channel. This was done to cut corners and get our first project done. I do plan to continue working on the software. One of my next tasks will be to make the interfaces…
Thank you. I am still polishing and testing a few things before this project is wrinkle free, but when it is a bit more refined I will consider a post on the community as well.
I experienced the same problem when reading the data with my own code. This problem is caused by the way the observations get time tagged. Observations are time tagged by the brainflow library at the moment they are received in your code, they are …
If you have a soldering iron, you can easily repair the broken wire. Simply strip a bit of insulation off the remaining wire and solder it to the back of the electrode holder. You can even make your own electrodes connectors from a few spare parts…
William Thank you very much for your prompt reply. Although I did search first before posting this question, after the fact I found this post on the OpenBCI forum which also explains the same thing: https://openbci.com/forum/index.php?p=/discus…
For what it is worth, I am also a newbie and I am working on a blink detector as a first project to understand more about EEG signals. I wrote up a bunch of notes with observations (and unanswered questions) that might help others who are also just…
