glo
glo
- glo
- Toronto, Canada
- 7
- Toronto, Canada
okay thank you I will try that
In the link that you sent https://docs.openbci.com/Cyton/CytonProgram/ -> "Note: occasionally, you may see the error message in the screenshot below. You can ignore this. As long as Program flash: ...................................###########…
Hi William, The change channels does work. The gui froze the first time so I restarted the gui, but I saw from system status channel was changed. Just in case, I changed channels again and it didn't freeze this time and the channel changed succe…
Hi William, Thanks, yup so I make sure that the working cyton and dongle were both turned off, and I also did try Autoscan (see first image in original post) it says that the "cyton and dongle are paired" and "cyton successfully connected to COM6…
