gilad
gilad
- gilad
- Israel
- 64
- Israel
Thanks William, As a workaround, I noticed that if I turn the Cyton board off and on again it solves the issue. Is there a command that I can send from the dongle to do the same? Sending the letter 'v' doesn't do the job, I understand this is only …
Hi William, I'm not using the GUI for my measurements, I calculate the impedance from the voltage measurements. The voltage itself is changing for some reason, and it changes suddenly after being ok for a few hours. Gilad
Hi William, These files are inherently 3D but are not something a mechanical designer can use... I'm looking for a one 3D file that has all the Cyton details in it. Thanks
@wjcroft said: The buffering on the Cyton mainboard RAM is minimal, only a sample or so until it is either sent to the RFduino radio or stored on the SD card. You are expected to remove the SD card and read it on your computer card drive. There i…
Thanks guys
Thanks, the open file in read mode method is working.
Yes the code increment the filename on each write. But, after 256 files the names are repeated and files are erased. I need a way to know the names of the files already on the SD. This is usually done by SD.exists but I don't understand how to use …
Hi William, you wrote "Another possible approach you could consider, is to count the number of samples in the period desired. With the 8 channel Cyton there are 250 samples per second." I tried to do it but couldn't make the arduino wait the time …
Hi William, Thank you for your reply. I can't use Lithium cell since we use it for a clinical use and as much as I understand they don't have the safety regulations for that although people say they are safe. So is there a way to turn off the RFdu…
Hi, I'm using a Cyton board for long measurement using AA batteries and can't use Lithium cells. I'm only writing data to the SD card and I don't need to use the RFduino to send data to the computer. I wonder how much current does the RFduino co…
