Default Avatar
gg_022006
gg_022006
Username
gg_022006
Location
india
Joined
Visits
35
Last Active
Roles
Member
Location
india
  • yes, we did because the jumper cable have excessive width we got some male to female jumper cables from our robotics lab and connected to that our cyton then the male side to the female side of the openbci cables this helped as connect all the chann…
  • This picture was clicked yesterday only as we are in India it follows DD/MM/YYYY format
  • We actually meant that we are using the official openBCI apparatus only, but as you can see from the image, once all of the pins are connected except one, there is not enough space left for the last pin. In this case, as shown in the image, the yell…
  • We are using an OpenBCI Cyton and are trying to connect all 8 EEG channels. We start connecting from the SRB pin and place the electrode leads on the row of pins closest to the board. Due to the limited physical space between the pins, we are unabl…
  • Thank you William , you're the goat
  • HI William, Thank you for your advice. We tried it, and it reduced our impedance to below 100 kohms. When we connected to all the bottom channel only for the cyton we were getting the channel railed for some reason that is why we didn't conside…
