ganglion_pulse
ganglion_pulse
- ganglion_pulse
- NZ
- 3
- NZ
Hi William, Had some trouble getting good signal quality ( with shielded cables ) etc, noise was an issue. Worked on coding up an ESP32 chip with ADS1115 adc and got it recognized as a Cyton Wifiboard on openBci, (The adc had a 16bit output only,…
Hi William, After adjusting the potential divider to reduce the voltages further down, to get it in range of <1000uV, Can see the pulse signal, It is noisy ( compared to the scope signal) and there is a DC offset which keeps the signal floa…
