Default Avatar
fma
fma
Username
fma
Location
Luxembourg
Joined
Visits
33
Last Active
Roles
Member
Location
Luxembourg
  • Thank you William for the papers you mentioned. I'll definitely read them. And also I agree with you on the accuracy of the field to be in flux and I believe that this is a job that needs to be done as the number of the usages are so wast and the f…
  • Thank you Retiutut for the effective response. You are right about multi-modal approach, We did a prototype with GSR and some research to integrate the PPG or HRV signals in our solution as well which seems to be crucial. But regarding the current…
  • Thank you William for the quick reply. The reason I asked about the papers, is because I already checked most of the related stuff and specifically the google search button in the forum for many combinations of Cognition, Affection, Emotion, and a …
