etc
etc
- etc
- Italy
- 302
- Italy
Thank you very much for your answers! PS I would like to say to you because I think that for Laura the EMG (neurofly) solution could be better: with the P300 speller but also with a VEP speller Laura has to look at the screen for a lot of time du…
Thank you!
@wjcroft Only to say to you that the software solution (Cvep by Mindaffcet) perhaps is not more available and running. I wrote a mail to [email protected] 3 days ago to get some more information but I didn't any answer.
Sorry! I didn't see this your sentence "One hypothesis may be that auditory P300 signal origins may be closer to the cEEGrid sites, but that this may differ for visual P300 tasks, such as your speller question." You write "may differ". Perhaps to d…
Thank you very much, you are always very gentle!
Ok! Then I have to control that the cap hole is smaller than the electrode size. Thank you. Ettore
Thank you for the lot of suggestions! I think that the only one problem is to know, before to buy one of these solutions, if the holes size (not the position) is good for my electrodes. You were very gentle! Ettore
Thank you for your suggestions!
Thank you! 2 doubts! I know that these questions are a little stupid... ! 1) I saw these items: https://brain-trainer.com/product/tc26-trainers-cap/ https://fri-fl-shop.com/products/19-channel-eeg-headband How can I be sure that the holes in th…
Thank you very much! You were very clear!!! Non it is only a problem for the electrode impedance, but it is a problem connected the amplitude signal. Thank you! ps a question: I would like to test the Openbci Combo dry electrodes (5 mm.) with the …
Thank you!
Dear Williams, @wjcroft, sorry if I am back on the same argument: the Gelfree BCI Electrode Cap. Sorry for these other 2 questions, but before to make the order (I would use the discount for this November!) I would be sure : 1) the Openbci …
Thank you! Last question: what tipe of electrode-Openbci did you use for the ground at Fpz? One of the electrodes of UltraCortex Mark IV? Thank you very much! You were very gentle!!!
Thank you, @jason! The gain for every electrode was the same of default or less than 8? Thank you!
(Sorry for my very bad English) @wjcroft, Dear Williams, thank you for your organizing the discussion! (I wrote some comments about ThinkPulse in this forum inside a discussion about “issues with my 2 Cyton dongles / speller apps [resolved]))"; …
Sorry for my English and sorry .. for the question, if possible! About 18 months ago in this forum I posed the problem of ThinkPulse sensors+Ultracortex Mark IV + Cyton not working while the Cap with wet electrodes + Cyton worked very well (BCI P30…
Thank you very much for the link. I gave a loook to the little manual. I understood that the use of these electrodes needs a lot of time! I read that before the use "Wet hydro-links : The hydro-links should be soaked with saline solution …
Thank you! In the next hours I will order the Gelofree BCI Eclectrode Cap kit + the Header Pin to Touch Proof Electrode Adapter (I would get the 15% off all OpenBCI-branded products... ). Another question: in the your documentation I didn't read …
Thank you very much! Do you think that is it enough to order only the kit or do you think that I need some other items to work for some months with the Gelfree BCI Electrode Cap Kit ?
Thank you!
Thank you very much! Ok! You are saying that Openvibe_GUI can run only with the administrator permission. I didn't know this information, thank you, now I'll controll! If I can give a little advice for the benefit of all the users, it would be an…
Thank you! Sorry, but I didn't understand: 1) Openbci_GUI can run only if it is in the folder Download? Do you confirm? 2) I dont'see anything in GUI screen that can be a measuerements of impedance (ohm). In the picture that I attached, where w…
A good news!!! I understood the problem! Eureka! But then I have 2 questions... When I download openbci Gui from your web-site, the download goes on folder Download; Winrar-unzip gives 2 possibilities: unzip on Download or unzip on another folder…
I gave a look to OpenBCI_GUI/Console_Data and I saw that there are a lot of data-set "Console+datastamp". But there is only one data-set with name Brainflow + timestamp, "Documents\OpenBCI_GUI\Console_Data\Brainflow_2021-11-08_12-58-44.txt". I thi…
Thank you, William! I am working and I worked on PC, not laptop. The old one was on win7. The new on win10. I remember that GUI 4.2.2 works on the new PC! The new GUI version doesn't run in win7. But I have a news for you!!! I used the my wife'…
Also without COM1, COM3 and COM4 GUI doesn't connect! Thank you! Ettore
Thank you William! This is the log: Console Log Started at Local Time: 2021-11-10_22-52-29 Screen Resolution: 1360 X 768 High-DPI Screen Detected: false Operating System: Windows Welcome to the Processing-based OpenBCI GUI! For more information,…
Thank you William! Two minuets ago I tried so: I inserted the dongle, then I started the GUI and then I put on Cyton. I used the "auto-connect". Same result, as you can see in the attacched picture. Then I tried: I inserted the dongle, I put on …
Only to say that I made a new order for some items and I got the discount "ETC" that you gave to me. Thank you, William!
