ericharshbarger
ericharshbarger
- ericharshbarger
- 24
Thanks. I'm traveling right now, so I don't have access to the Ultracortex. But I think I was having more trouble with having both the front and back electrodes touch my head at the samw time. I had someone else try the Ultracortex and I think they …
I ordered the medium sized frame, which is for 50-55cm. I just measured the circumference of my head, and it's 52cm.
Yeah. I've tightened the electrodes all the way. Still not all them are touching my scalp. And it's (almost) painful wearing it.
Yeah. That's how I have it set up. I have the Ultracortex on snugly. Also It seems like not all of sensors on the Ultracortex are making contact with my scalp when I have it on my head
I think I have a solder sucker tool. Actually the Daisy might be working. It might just be that I'm having trouble getting the Ultracortex into the right position on my head so that all channels show activity at the same time
I have ear clips connected properly but still get the problem. I tried using one channel only, Ch1, and connecting it to the OpenBCI and it works normally. I followed the tutorial you linked to and tried with more channels connected only to the Open…
Maybe I don't have the ear clips connected correctly. I have the yellow wire that goes to the ear clip connected to the bottom SRB pin on the Daisy, the white wire connected to the bottom SRB pin on the OpenBCI, and the black wire connected to the b…
Yeah. I'm sure everything's connected
Ok. Thanks. I think I was able to it figure it out. The GUI shows activity for most of the electrodes when I'm wearing the Ultracortex only if I do not have the 2 ear clip electrodes on. But whenever I put on the 2 ear clip electrodes on all the oth…
Ok. So then purple on the Daisy would be Channel 10? Maybe my question wasn't very clear. I wanted to know which channel numbers correspond to which pin numbers?
Thanks. I already read the link. The picture and link don't show which color wires go to which number pins though. Can you please help with this?
Thanks. I read the links. I'm still not following which color electrodes go to which pin numbers. I want them to correspond to the default mapping in the OpenBCI GUI. Can someone please post a list of it of the mappings for the OpenBCI and Daisy? I …
