erasmus
erasmus
- erasmus
- 87
no
I just received mine.
should I have received my board by now? Cause I haven't
I purchased a Ganglion in July. Can you please update us all on when these boards will be shipped and what seems to be the problem? Is it possible that you just didn't get my order even though I have an invoice?
WHAT IS GOING ON WITH THE GANGLION BOARDS?
Any idea if we will receive our orders before the holidays?
I can't believe I'm still waiting on this Ganglion board. Are there any new updates? We are already into December.......
Where's the amp?
http://www.pamel.hr/index.php/hr/proizvodi/eeg-kape-elektrode-pribor/2012-11-05-09-59-48 Oh I think I get it. Those grey, hard plastic bridges can be placed anywhere. They seem like they might have small springs in them as well. So from there coul…
I've tested this cap and they work really well. http://www.medcat.nl/supplies/capcmby.htm I wonder if they would modify it with quick connects.
it's the base in which the quick connect attaches to the electrode. It sorta snaps in. I can see how that would remove the plastic coating sorta like enamel on teeth.
They are composed of a conductive AG/CL coating of a conductive plastic. They should be able to be used at least 20 times. The limiting factor is that the coating will be removed through multiple attachments of the electrode lead.
Received 2nd quote from another source. $732.56 for all the parts. I'm guessing most people here will just order from OpenBCI or by their own 3D printer. I'm so confused over all of this. I still cannot believe these pieces of plastic should cost so…
sorry about the bad paste job.
This is what I was told: The time to print all of the parts is roughly 72 hours. We typically give a two week lead time for projects this large. I hope you understand that this is a large volume of material and time for printing and I have to fol…
typo I was quoted THAT a complete unit would run $1036.80 for the parts.
[24-channel board configuration query] I'd like to build a 24channel system that can be used to capture at least 19-channels of EEG and then run it through Neuroguide software to do neurofeedback training. Can we daisy chain 3 8-channel boards …
