elizabeth
elizabeth
- elizabeth
- los angeles
- 63
- los angeles
- Website
- www.the-tarot.com, www.lisaconsulting.com
- @LisaSmirnoff
- Interests
- meditation, journalism, tarot, fashion, cooking, any kind of sport activities.
- marpasoft
Thank you. I want to learn as much as I can get for my own knowledge to have a big picture of what happens in a brain. The more I know the better I feel.
Not yet. I want to make sure that the mistake is not on my end. maybe settings. I am not a programmer. Its just one of my work projects.
It does not see OPenBCI again. It worked last night.
Yes, sure. Do you know if there are articles on practical applications on neurmore. I just need to learn and test all the features. It will be very helpful. Thank you!
Its resolved.
I mean for OpenBCI software which gives a feature to see each channel separately.
It works - when I remaned txt file yesterday night and deleted description above. I just look for next steps to deal with data.
It worked with a new release of beta version. I can do it now. I just need to learn practical benefits of this product.
Thank you. Will be testing now. It works, and shows each channel separately. Could you please, send me exe file because the processing is programming tool and it is a bit complicated to run it in front of my boss. You make me become a programmer. wh…
Thank you!
@retiutut said: 1. The next public release of the GUI will allow you to select what TimeSeries channels you would like to view, not just disabling them. I checked the repository. Could you please approximately tell me the time frame for t…
I did post two tickets.
Thank you!
I double checked the settings, restarted a computer a few times. Nothing works for me. I wonder why.
When I made changes to 1 second in the port, my computer started to be acting out and makes it virtually impossible for a mouse to work.
https://www.youtube.com/watch?v=1jlf233CVig I watched the video and it does not make the OpenBCI appear under devices as it shows on the video. I just wonder what did I do wrong.
Somehow I did install the software and run data stream, but seem not to understand how to connect EDFBrowser. It does not see it.
Thank you very much. If a release to be done soon with each channel separately, this is all I need for now. - I am left with a questions what software best will fit my needs and where cvs file records and if openbci software records it because as I …
Thank you very much. Could you please, let me know how soon a new public release will be. This is for my work project and is very important.
I saw the same discussion. 16 channel shows data either its on or off. My question is could it be a mistake in installation (my mistake). The other channels do not have the same problem. Any suggestions? We just have purchased it and its the first I…
I found the other info, in case anybody is interested.
