duncancipher
duncancipher
- duncancipher
- United Kingdom
- 15
- United Kingdom
Brilliant! Looking forward to this Any idea when it will be released to us?
Thanks William. I'll look into this. I was hoping it would be possible, perhaps as a separate widget. If I get it to work I will post up a repository, perhaps others might have a use for it too.
I guess that is a no, then
> You can connect the pulse sensor and 2 Myo's to the J3 Aux pins. Leaving all 8 EEG channels available on the mainboard. Ok - but for power and earth to more than one sensor...? (With the Daisy on): Are you suggesting a Y lead off of J3? Do yo…
that's helpful thanks William. I see the VDD and GND on J3 which could power a sensor. I don't have a specific application: but I would like to be able to use 1) 8 channels of EEG 2) the Myo and 3) the pulse sensor at the same time. being able…
Thanks William. So for clarity (also if others with same idea are reading this in future): 1) If I connect pulse (or Myo) to Daisy, there is no where to power or ground either sensor from, correct? 2) Therefore suggested use of pulse (or Myo)…
Hi William, Thank you very much for this response - much appreciated. I think I may have mis-understood the purpose of the Daisy, then. Is the Daisy really only used when adding additional EEG electrodes? What I hoped to do was measure 8 chann…
