dream4future
dream4future
- dream4future
- Warsaw, Poland
- 264
- Warsaw, Poland
- Website
- https://www.youtube.com/@pyotreus
- Interests
- Neuroscience, Consciousness, Programming, Engineering, AI, combining technologies
Hi there, 'No attribute' error very often is caused by the wrong library version. Make sure pyglet version is correct. Check the requirements.txt P.
MindAffect also works with fake data. Lets break this down: 1. You run the app 'online_bci' with fakedata_test.json file. 2. In the main menu you choose Calibration. After calibration you should see the result of that process (100% success) 3. No…
Hmm from your screenshots it looks good. Java version also should not be the problem here. Have you done Calibration before going to Cued Prediction? Remember that without calibration (training Machine Learning model) the prediction wont work.
What Java version do you have? When you go to Electrode Quality do you see that all electrodes have value 0.5 that doesnt change?
I received some questions regarding MindAffect installation. I didnt mention about that in my tutorial but there might be some problems with execution pip install -r requirements. txt command. If you are lucky to have this error just install librar…
William, thanks for sharing it! In case anybody had a question you can send me an email: [email protected] Best regards, Pyotr
Hi William, Thanks for your reply I sent you a DM with some questions. Best regards Pyotr
