daniellasry
daniellasry
- daniellasry
- WA
- 35
- WA
Hi @javad We have no current plans to re-add the interpolation. In 4.0 we added interpolation to mask a software issue that was causing regular packet loss in the wifi shield. In 5.0 we fixed this software issue. Now there should be less packet …
@ayau3 Take a look at the python example in the brainflow docs: https://brainflow.readthedocs.io/en/stable/Examples.html#python This example streams for 10 seconds (time.sleep (10)) and prints all the data collected in that time. You should be ab…
hi @zfmeng, I would like to make a permanent fix. Do you still have a screen shot where I can see the issue? The link above is not working for me. Could you re-send? Thanks!
Hey Omar, I replied to your issue here: https://github.com/OpenBCI/OpenBCI_WIFI/issues/86#issuecomment-451568232 Hopefully that gives you some clarity on what's going on. Unfortunately there is no immediate fix, analog mode is not implemented in p…
