coreygo
coreygo
- coreygo
- 129
- Website
- https://coreygo.com
- @coreygouker
Greetings all, v4.0.2 has been released a pull request to update Homebrew's driver cask has been merged: https://github.com/Homebrew/homebrew-cask-drivers/pull/629 MacOS Homebrew users can now brew cask upgrade openbci-gui to update to v4.0.2. The…
Opened: https://github.com/OpenBCI/OpenBCI_GUI/issues/386
Hi William, Yep. For v3.4.0 I'm using Hub v1.4.5. I've also tested with Processing 3.4.0, OpenBCI GUI v4.0.0-alpha.1 / Hub v2.0.0, that log is here (init timeout when starting the system): https://gist.github.com/coreygo/a06cea595e8bd4a8f1f0300682…
Oh awesome, figures... should've assumed
Well, I'm sure this isn't the best solution I've managed to keep the oscilloscope and buttons inside the playground. It'd be super helpful if there were a xPlaygroundCenter and yPlaygroundCenter variable to align playground UI elements. I've done t…
Okay, just confirmed that on 10.11.1 if you're going to use FTDI driver v2.2.18 you'll have to boot to Recovery OS (CMD+R) bring up Terminal and run csrutil enable --without kext after rebooting installation and modification of the plist file will w…
@wjcroft Yep, so it's definitely enabled. @marion I think you're onto something. Found these two resources: http://osxdaily.com/2015/10/05/disable-rootless-system-integrity-protection-mac-os-x/ and this http://apple.stackexchange.com/a/209530 threa…
Yep, I believe so. I definitely ran sudo nvram boot-args="kext-dev-mode=1" and rebooted before proceeding. Also checked my settings to allow apps from anywhere. I've noticed the same regarding jumping to the latest and greatest. I guess I'm somewha…
I just tried the guide with 2.2.18 on OS X 10.11.1 and unfortunately it's refusing to work with the plist modifications. Checking Console reveals "Untrusted kexts are not allowed invalid signature for com.FTDI.driver.FTDIUSBSerialDriver". Modifying …
Thanks. I've considered both of those options but wasn't thrilled with either. The Brainnet seems cheaply done and the g.GAMMAcap is a bit too much. I was hoping to find something for $100 that wouldn't need the gel so it'll last for regular use. L…
I left the wiring on my Mark III practically full length and zip tied them neatly to reduce movement and keep things relatively clean. I wanted to be able to just cut the zip ties and move stuff around if necessary. Pretty much what wjcroft suggeste…
Greetings all, I've been testing audio files created by Transparent Corporation for NeuroProgrammer 3 as well as some other online binaural audio files and such from sites like Brain.fm. Here's a 30 minute recording I uploaded to YouTube to demonstr…
Also take a look at http://www.neuromore.com/developer/
I would definitely be interested at that price point since Sculpteo is ~$750. Even more so if you're sourcing the nuts and bolts. I don't mind getting my hands dirty at all and was figuring I'd need to take the leads from the full kit and have to st…
Nice, thanks Conor! I'm holding off and getting more quotes from different options. Right now Sculpteo is the cheapest and best third party I've found -- quite crazy considering they're in France. Any chance the crowdfunding campaign will see headwa…
For reference this is the total cost from Sculpteo with 1 complete frame and 22 (1 extra) sets of small parts.
Uploaded to Shapeways for printing: http://shpws.me/JN5R (frame front $37.78) & http://shpws.me/JN5H (frame back $53.85) It's reporting potential issues with thickness in some areas however I don't think that's correct. I've contacted Shapeways…
