clatoxen
clatoxen
- clatoxen
- Italy
- 33
- Italy
We are using dry snap electrodes with athletes ( no time for gel or wet) and we can use only forehead. The signals looks good in the GUI while the band power shows strange spikes. I was also wondering how it was computed the numerical value of the r…
We used Processing to add a stress-related formula and generation of the index and wave components in . csv who created this table. So here there are no problems with raw data per se but should I essentially remove the DC component by applying a fil…
Hi, thank you! This is the difference between commercial eeg with 1 channel (up) and openbci also 1 channel (down). I'm using the dry electrodes with good pressure on frontal lobe. The results of Openbci waves is good or maybe there is something…
