christihan
christihan
- christihan
- Peru
- 46
- Peru
Thanks wjcroft. It works with the USB wired link but now I have another question. If I use the USB wired connection, the peripheral bus clock to send the packages is 8MHz? If it is, I've found this guide: http://ww1.microchip.com/downloads/en/Device…
If I change the 8 MHz external clock to another with higher frequency. Could it be posible to increase the baud rate to 230400?
I need to increase the sample rate to 500 but with this sample rate I can't send the 31 bytes per sample in less than 2ms to recieve all the data because of the baud rate so I want to send only 4 channels to make this possible. Could this be done?
Thanks for the reply but I mean that I want to send only 4 channels data instead of sending 8 and then power down 4 channels.
