chriseb
chriseb
- chriseb
- 51
Yes I did use OpenBCI_32bit_16channel repository. I honestly don't know what happened. One day it was working fine the next day it wasn't. So I'm afraid I can't be of any help in replicating the problem. Thank you for all your help!
Yes I did say that in my post from May 25th (http://openbci.com/forum/index.php?p=/discussion/comment/2387/#Comment_2387) I must admit I hadn't thought to try just the main board by itself last week since I only ever use 16 channels. So after test…
If the problem is with the daisy can we get a replacement?
Well I was able to successfully upload the blink sketch and it worked perfectly. However, when I re-upload the OpenBCI firmware I still get the same issue when using processing. The following is the output from processing: ControlP5 2.2.2 info…
Well now I'm not even getting anything when I send a "?". I've tried re-uploading the firmware again and nothing changed. Is this fixable?
Well I uploaded the new firmware. It took a couple of tries but I followed the instructions in another post (chipKIT uploading tips and restarting bootloader) and was successful. However now I keep getting the error "init timeout...retry initializat…
Alright I will try that. Thanks
Yes it is a strange problem. I did as you suggested and the following are the screenshots and output from processing. Even though the board and the daisy are healthy, I am still missing 8 channels of data. 1) 16 Channels nothing connected - sc…
Nope, I've never changed the firmware.
Thank you for helping me to troubleshoot this problem!
So I tried running it using the latest processing sketch on another windows computer and a Mac. It didn't fix the problem.
No I haven't. I'll look around and see what computers I can borrow.
I tried as you suggested and deleted and downloaded the latest processing sketch. No change. I still have the same problem.
The following is the output from processing: ========================================================================== ControlP5 2.2.2 infos, comments, questions at http://www.sojamo.de/libraries/controlP5 OpenBCI_GUI: setup: RESIZED OpenBCI_GUI…
Thanks for your help!
The CS2 pin seems pretty firmly in place. We tend to not take the daisy off so there shouldn't have been too much wear on it. Do you know if there are any loaners available? Unfortunately I was in the middle of an EEG study when this happened so …
William, So I had it working for about 3 months before it began doing that last week. I just inspected the soldering and it looks fine (everything is still connected). Chris
Thanks for the suggestions. After experimenting the problem seems to be resolved once we updated the driver, updated our Labview drivers, and re-soldered the daisy onto the board. The past two weeks we have been using it every day and the pr…
