brainiac
brainiac
- brainiac
- 23
Hi Again @wjcroft and @retiutut, Sorry for my delay. We needed to keep going with work and left this issue for the last and could not reply sooner (COVID had a lot to do too). So, I was reading some posts regarding my issue and I discovered you h…
Thanks @wjcroft. Well I actually tried at different locations and these artifacts are invariant. Also gets worse using WIFI shield. I am using dry electrodes (the ones with spikes) and tried tightening them as much as possible (actually until pain).…
And sorry @wjcroft, I've updated Cyton's firmware to the latest and we bought the gear last year. I also downloaded last GUI version two weeks ago.
Thanks a lot @wjcroft ! I DO HAVE the WIFI SHIELD. The artifacts I mention looks like a periodic (maybe every 1 or 2 seconds) "impulse response", synchronized in every channel. The picture shows the case when I'm using BLE (took out the wifi SHield)…
To be clear, using this sequence of commands leads me to a 250SPS (apparently, based on previous post in this Forum) signal with no timestamp (that's why apparently). If I used marker mode, I can se marks whenever I introduce them, so It works in th…
